1 - 2 of 2 Posts
Hi guys! So I was wondering if anyone has ran into this issue. The oil line that runs from the crank case to (im guessing) the turbo is leaking. I've provided a picture for reference (the picture is with an aftermarket turbo) I'm currently running stage 3 on the stock turbo. There is a good amount of oil that's leaked to the bottom of the oil pan. I've tried tightening it up good but it's still leaking. Was wondering if anyone has encountered this issue and if you've found a fix
1 - 2 of 2 Posts
