You can view the page at http://fordstnation.com/content.php?r=197-M-Day
Chad, you rock!Just an update for all.
The files are transferred and the data base is over there. So the change will happen within days from now. I will try to let you know exactly when we will be transitioning.
Chad
ThanksChad, you rock!
I think once I get everything sync, I can do this for sure.A minor suggestion - if you have an IP for the new server, perhaps post that publicly so we can still access it while DNS is populating?
Disclaimer: I am not a networking tech, engineer, or anything of the sort. I just fix easy problems from time to time.
No Problem, as I was looking over things this afternoon, it looks as if that the timetable will be pushed off one day.Thanks for the above timetable
Scott,Will all of the posts extant transfer or will we be starting over?
