1 - 6 of 6 Posts
Hey everyone I just purchased a Fiesta ST on black friday (the rebates were too good to pass up!) and I've been playing around with all the features and I noticed that the drivers side power window is auto down but does not appear to be auto up. Is this how all US Fiesta STs are or does mine need it's software tweaked at the dealership? Thanks!
On the Focus, if it stops working the reset is simple. Roll window all the way down release switch and then quickly press down and hold a few seconds. Repeat, but this time roll the window all the way up, release the switch and then hold in the up position for a couple of seconds.
Try this procedure a couple of times. Usually rests the window. Can be used on any window that stops functioning.
There is a way you need to reset the auto up function it is in the owners manual someplace .. I'd look it up but I'm not near my book.. I had to do it after taking the battery out to install the quick shift from Mountune.. Iirc it's just using the up down button on the door to set the limits for the auto up function ..
Thanks for the info guys. I will give it a shot when I get home tonight. Loving the car so far!
Here is how to reset the Auto Up feature by resetting the Bounce Back Feature
Page 72 or so in the manual under Windows and Mirrors
Bounce-Back (If Equipped)
The window will stop automatically while
closing. It will reverse some distance if
there is an obstacle in the way.
Overriding the Bounce-Back Feature
WARNING
When you override the bounce-back
feature the window will not reverse
if it detects an obstacle. Take care
when closing the windows to avoid
personal injury or damage to your vehicle.
Proceed as follows to override this
protection feature when there is a
resistance, for example in winter:
1. Close the window twice until it reaches
the point of resistance and let it
reverse.
72
Fiesta (CCT) Vehicles Built From: 11-10-2013, Vehicles Built Up To: 31-12-2013
Windows and Mirrors
2. Close the window a third time to the
point of resistance. The bounce-back
feature is now disabled and you can
close the window manually. The
window will go past the point of
resistance and you can close it fully.
See an authorized dealer as soon as
possible if the window does not close after
the third attempt.
Resetting the Bounce-Back Feature
WARNING
The bounce-back feature remains
turned off until you reset the
memory.
If you have disconnected the battery, you
must reset the bounce-back memory
separately for each window.
1. Lift and hold the switch until the
window is fully closed.
2. Release the switch.
3. Lift the switch again for one more
second.
4. Press and hold the switch until the
window is fully open.
5. Release the switch.
6. Lift and hold the switch until the
7. Open the window and then try to close
it automatically.
8. Reset and repeat the procedure if the
window does not close automatically.
1 - 6 of 6 Posts
