So today I was taking a coworker on a ride in the ST. I went to turn the ESC completely off. The first visual part of changing the setting on my display completed, but the second part saying that is was turning it off went about halfway thru and then disappeared. I looked and the ESC was still turned on. I tried this several times. After the first go, it seems the button stops working. But if I shut the engine off for 10 seconds and restart it you can try again but it still gets halfway thru then goes away. Anyone else having/had this problem yet?
The only thing out of the ordinary with my car is that I changed the wheels and tires over with a winter set with no TPMS installed so I have a constant Tire Pressure message light on. Could this be causing an issue?
