One major thing that can be affected with intakes is the MAP sensor. If water or oil or anything get onto it you may get a CEL.
I would suggest this b/c it is cheap and easy. Try cleaning the sensor and re-installing. Plus you will have this cleaner for the future. It isn't a bad idea to clean the sensor every time you clean or replace your air filter.
This stuff should work:
CRC/Mass air flow sensor cleaner (05110) | | AutoZone.com
Otherwise talk to Cobb. They may know something specific to look at.
