Just leased a '14 Silver ST.
Ah that new car smell.
A few impressions after 6 wks:
1st: The car has already spent half a month at the dealership for service. First it was the rattles in the gauge cluster and shifter, when hitting 1st/3rd,5th (the reverse lever rattles against the main shaft.
Then it was a check engine light (crimped wiring harness coming off the turbo?)
Then it was a "microscopic" coolant leak, causing the car to overheat (temp. needle pointing true north)
2nd: The power is exhilarating.. until it hits the last 3rd of the band. Then it plateaus. I suppose this is normal, especially for a turbo 4?
3rd: Holy lift off oversteer, Batman! I've come close to losing this car more than once just on spirited drives through canyons. Seriously, I've driven a few cars and this one inspires the least confidence. Everything's fine until you let off completely in a high speed turn. Is this expected behavior?! It's like the thing tripods on command, lifting the inside rear tire like a 64 Impala.
4th: LOL @ "torque vectoring." Jesus Christ. This thing needs an lsd like Ralph Stedman needed LSD.
Other than THAT, it's great, lol.
Any thoughts? Can anyone else empathize or am I just doing it wrong?
SJ
SJ
