1 - 20 of 53 Posts
I had originally ordered an ST1 because I was going to replace the stock radio anyways with better components but I found out that the only face plate available from Metra looked horrible and made the car look cheap. I decided to purchase an ST2 but upgrade all the speakers and subwoofer while using the stock radio. I'm actually happy I got the ST2 b/c I really like Ford's My Touch. The speech recognition is just unbelievable when I tell it an address to route to.
Anyways, as for the stereo, it does sound decent but the major weakness is the sub. Its not clean sounding and ends up distorting the mids and tweeters. There's not a lot of room in our trunk so I decided to use a shallow mount sub to mount in the corner to replace the stock sub. I'm not a fan of putting big sub boxes in the trunk b/c it's not aesthetically pleasing and takes up too much usable space. I fiberglassed a sub box in my last car so decided to do one for my ST.
First, in order to remove the stock sub, you would need to remove the spare tire and then unclip the wire that attaches to the sub. It's attached to the green connector in this picture and you just press the tab to unlock it and pull it out.
Remove the foam that sits next to the spare tire and you'll see the 3 bolts that hold the sub in place:
This is what the sub looks like removed from it's enclosure:
I plan to replace it with an Alpine SWR-T12, it only requires a 0.6 cubic foot sub box and is 3.5 inches deep:
Things you will need:
Fiberglass resin
Fiberglass mat or cloth (I find the cloth is easier to work with)
disposable plastic cups
disposable gloves
Ventilator
painters tape
petroleum jelly
acetone
cheap brushes
First thing you'll need to do is tape the area you want to fiberglass. It's very important that you double tape everything because the resin will stick to anything and once it's on your carpet/plastic trim or car then it'll be there permanently. I then outlined the area where I want the sub box to be with a marker.
Apply a generous amount of petroleum jelly to the area, it will serve as a releasing agent to help you remove the fiberglass frame later.
Now cut up the fiberglass mats into smaller pieces, about 4x4 inches. Make sure you wear gloves and use a ventilator mask when working with fiberglass.
Mix up a SMALL amount of the resin in a plastic cup. In a red solo cup, I usually pour to the first line at the bottom and add about 20-25 drops of the hardening agent and mix it really well with a plastic spoon. Use the brush to dab a small amount onto the painter's tape and then lay a fiberglass mat on it then dab some more until you soak the mat thoroughly. It'll turn from white to clear once it's soaked thru. Move from one area to the next, using only a small amount of resin at a time because you only have about 15 minutes to work with it before it hardens. Don't mix too much at a time or else you'll just waste it. In between mixing the resin, be sure you place the brush in a glass of acetone to prevent the fiberglass resin from hardening it. Here's what it looks like after 2 layers:
Add about 4 layers of resin & mat and l let it dry overnight. I used a screwdriver to carefully pry at the corners and loosen all the outside edges.
Once all the edges are pried apart, yank on the bottom (holding onto foam insert) and you can hear it slowly releasing. This is the most difficult part because it's stuck on pretty good but if you pull on the corners, you'll eventually get it freed.
Clean the back side of the fiberglass frame with some dish washing soap to clean off the petroleum jelly. After cleaning it, I put it back into the car to mark where I need to trim it.
Using a dremel, I cut it to the size I want and file away the rough edges. Here's the final back side of my sub box.
Discussion Starter #2 (Edited)
The next step is to attach the sub ring that I had cut out of an MDF board. I used hot glue to attach the dow rods and then glued it to the back of the sub box.
Now take an old T-shirt and stretch across the front of the sub box and use the hot glue to secure it down.
I then used a marker to outline where the border of the sub box is
Soak the T-shirt thoroughly with resin and then layer it with fiberglass mat
I'll let it dry overnight and then cut out the center and continue layering the resin & mat from the inside.
Discussion Starter #3 (Edited)
Here's the box with the center cut out and after some rough sanding:
Test fitting the sub into the box:
Making sure the box fit into it's corner:
It's a tight fit, but I'll make it fit. I'll just need to file away some of the foam inserts.
I then applied some Bondo and then sand it down with 40 grit sandpaper to even it out as much as I can:
I bought some black car carpet from Autozone and used Loctite spray on adhesive to glue the carpet to the box.
I'm not very good at carpeting, there's some seams that I'd rather not be present but this is the best I could do:
And with the top cover on, it's hidden from prying eyes:
Love it. I was thinking the same thing, filling in that whole side and coming to about the same spot the stock sub goes, should gain a decent amount of airspace by going that route. Looking forward to the updates.
This is cool. I installed custom stereos while in college. I haven't done something like this in years. If I could make what I make now and install stereos that is what I would still be doing. Looking forward to seeing how tis turns out.
Wes
Discussion Starter #8
Thanks for all the encouragements! I just got home from work so didn't get a chance to work on the box tonight. I'm off tomorrow so should have some updates for you guys soon.
Discussion Starter #9
Are you planning on just using the stock amplifier or are you adding an aftermarket ontop of it?
No, the stock amp won't be able to power a decent aftermarket sub. My setup will consist of:
Dynaudio Esotec components up front
DLS coaxials in the rear
Alpine sub
JL HD 600/4
JL HD 900/5
Bit One processor
I'm still debating how to connect the stock radio to the Bit One. I've read some posts where I'm told to wire it before the stock amp while others say the signal is too low so I would wire it after the stock amp. I'd prefer to wire it before since the amp may distort the signal.
Alpine sub
JL HD 600/4
JL HD 900/5
Bit One processor
Wow that looks pricey! What is your total cost so far?
Where are you going to mount the amplifiers? To the back of the back seats?
Discussion Starter #11
Most of the stuff were taken from my other car.. Only the speakers and sub are new, so it wasn't too bad. If you invest in quality stuff originally then you can use them in your next car and not worry about wasting them.
The processor will go over the stock amp and the 2 amps will be placed right next to the stock amp. I will have to cut into the fender foam to make them fit but I don't like the look of amps screwed to the back of the seats.
Nice work, thanks for sharing. Very curious to see how the wiring goes with the MFT.
Are there any diagrams available yet for the MFT Focus? I've been checking the12volt but nothing is up yet.
I really enjoy watching projects like this evolve. I've only ever done a little bit of fiberglassing in my life (college project) and man did I hate it. :) I've never done much with audio systems in my cars - always having preferred go-fast parts. But really am liking your project so far.
Side question - I remember itching like crazy after working with fiberglass (particular after sanding). What's the trick?
Discussion Starter #17
I plan to tap the front speaker wires and connect them to my Bit One processor and use them as inputs.
Discussion Starter #18
I haven't had any problems with any allergic reactions or discomfort when I work with fiberglass. Just make sure you wear gloves and use a ventilator and you'll be fine.
Discussion Starter #19
The Alpine sub needs 0.68 cubic feet of space, which is approximately 5 gallons. I took this picture and asked my brother if he thinks the box is big enough.
He didn't think it would hold 5 gallons and I questioned my initial measurements. There's only one way to find out, here's a 5 gallon bucket filled with water:
And the result:
Sorry, bro, you owe me a steak dinner :yay:
1 - 20 of 53 Posts
