1 - 2 of 2 Posts
Director of Art
Here's the writeup is from another forum
Pics are included for the rear
PRT = panel removal tool
Front doors
1. Use pick to remove screw cap cover behind door handle.
2. Unscrew (1) T-20 torx behind screw cap just removed.
3. Use PRT to unclip side trim around window switch panel.
4. Unplug window switch panel and remove.
5. Unscrew (2) T-20 torx from behind the panel just removed.
6. Unscrew (1) T-20 torx located on the side of the door panel.
7. Use PRT to unclip red reflector lens.
8. Unscrew (1) T-20 torx from behind the panel just removed.
9. Use PRT to unclip door panel, unplug and remove.
10. Unscrew (3) T-27 torx securing the speaker, unplug and remove.
Rear Doors
3. Use PRT to unclip window switch panel, unplug and remove.
4. Unscrew (2) T-2 0 tor x behind the panel just removed.
5. Use PRT to unclip the door panela round outer edges
6. Push Door latch out and twist slightly to disconnect door.
7. Unscrew (3) 7mm bolts securing the speaker, unplug and remove.
8. CAREFULLY peal noise reduction foam back
To reinstall just reverse the order.
1 - 2 of 2 Posts
