Hello!
My car has the problem that it idles erratically.
I checked the sensors and with the engine off I get good results (All around 100kPa).
When I start the engine and read the sensors the MAP sensor shows a much lower value than the other 2 (40kPa).
I also checked a car of a friend of mine to see if he had the same results and he has the MAP sensor the same as the other when the engine is idling (100kPa). He has a 2021 Ford ranger.
Do you have an explanation for this?
100kPa = 14,5psi
40kPa = 5,8psi
Verzonden vanaf mijn iPhone met Tapatalk
