Hey,
So I've owned my ST3 56 plate for year and a half now and I've recently developed an issue with a knocking noise from what sounds like the front left (passenger side) when switching from driving forward to reverse? and then sometimes when pulling off/changing gear at low speed. I have already replaced the lower engine mount with powerflex bushes and this only appears to have made the noise slightly quieter. I believe this could be related to a mount or suspension of some kind as you can get the noise to occur easily when switching between facing up a steep hill to facing down it. Not sure where else to check?!
N.B. I have had the driveshaft nut replaced about 4 months ago as this was missing, however the noise happened shortly after, sounds different and doesn't occur with any speeds roughly above 30mph
Any suggestions?
Any suggestions?
