PRODUCT INFORMATION
The KW coilover suspensions for the 2013 Ford Focus ST enables the owner to lower their vehicle 25-40mm on the front axle and 20-35mm on the rear axle and retains enough travel to handle maximum load and dynamic loads during driving. Adjustable (and independent reacting) rebound and compression damping allows a truly individual performance driving setup for those technically demanding drivers. Compression dampening adjustment is conducted in the low-speed range, while the high-speed set-up, so decisive for driving comfort, has been pre-se t by KW engineers. All KW coilovers come with a lifetime warranty and pass stringent German TÜV safety & quality testing standards.
Features:
Damping technology with individually adjustable rebound- and compression technology.
inox-line stainless steel technology.
Individually height adjustable.
Adjustment parameters approved by the German Technical Control Board (TÜV).
High-quality components for long durability.
Infinitely variable rebound damping adjustment.
14-way adjustable compression damping.
Unique, individually working damping force adjustment.
Comprehensive documentation for easy use.
Based on vehicle specifications, the rebound damping is adjusted by a spindle at the end of the piston rod. Mainly, the traction phase (rebound) controls car body vibrations and influences handling and comfort in the low-speed damping range. By using the traction phase adjustment, the vehicle can be fine tuned to the requirements of the driver. Moreover, driving behavior can be regulated from comfortably rolling to sporty and tense with improved road holding characteristics.
The compression phase adjustment is carried out at the lower end of the shock absorber via KW’s patented multi-purpose valve. The large number of pre-set parameters on this valve allow for a wide range of adjustment for individual use. The unique low-speed compression adjustment distinguishes this technology from any other. In this compression range, the driving behavior of the vehicle is drastically influenced. An increase of the damping power supports the vehicle already during compression and therefore avoids rolling and pitching. The directional stability is significantly improved.
PRICE FOR ST NATION
VARIANT 3 (SHOWN ABOVE) $2200.00+s&h
VARIANT 1 $1700.00+s&h
Features:
PRICE FOR ST NATION
