1 - 3 of 3 Posts
had my focus st3 front wheels tracked i will put the print out up for you to see. my issue is the right front camber is out went bk they said it cant be adjusted help plus my car is slightly pulling to the right
It can be adjusted. I had my car aligned to a custom setup several times for auto x. All they have to do is loosen the engine cradle and shift it to even out the camber. super simple 4 bolts and it can be moved.
with the McPherson strut setup the only adjustment on the front of the car is the toe... I have never heard of adjusting anything in the front via the engine cradle. I did about a dozen alignments on my previous vehicle and only set the toe and never had any tire wear or handling issues and I dropped the car 2 inches as well. I'd like to know what place supposedly set your camber by shifting the engine cradle.... sounds very odd to me.
1 - 3 of 3 Posts
