1 - 2 of 2 Posts
What’s up fellow st drivers 🤙 so as the title states, Iv got this oil leak that I can’t seem to track down.. Iv got a 2016 focus st, injen intake, turbosmart bov, stratified stage 1 93 oct tune. The other day I noticed my oil was about a quart low. Pulled the belly pan and low and behold, oil everywhere around the turbo.. I did a ton of research on common leak areas and none of them seem to be the root of my problem. I pulled the intake off, it’s clean, I pulled the hot charge pipe off, also clean, both the feed and return lines were fairly clean, the heaviest amount of oil lied around the bov, so I pulled the bov and that was also clean.. the timing chain cover also appeared to be clean and it looked like it had been sealed with some sort of black sealant rather than a gasket so I’m not sure if that’s factory or not.. the car is out of warranty and I’m trying to avoid the stealership so any help at all is greatly appreciated!
1 - 2 of 2 Posts
