1 - 4 of 4 Posts
NEW FSWERKS 25MM REAR ADJUSTABLE SWAY BAR – FORD® FOCUS ST ECOBOOST 2.0L 2013-2016
The NEW FSWERKS rear sway bar is designed to improve handling and stability without affecting ride quality.
The adjustable design allows the end user to fine tune the sway bar from firm to normal within minutes.
We developed a 25mm diameter solid bar to improve steering response, reduce understeer and keep bodyroll in check.
The FSWERKS mandrel bent sway bar kit includes stiffer polyurethane bushings for quicker suspension response,
and all the necessary hardware to ensure a factory like fitment.
The FSWERKS sway bar is compatible with stock and most aftermarket endlinks.
* 25mm two position adjustable rear sway bar
* Developed for street or track use
* Comes with polyurethane bushings
* Satin black powdercoated finish
* Weighs only 13.5lbs
info/order click here: FSWERKS 25mm Rear Adjustable Sway Bar ? Ford® Focus ST EcoBoost 2.0L 2
I have a rear shock tower brace installed on my ST now, will this hinder the operation of your sway bar if I install one?
Discussion Starter · #4 ·
With our Rear Sway-Bar installed, this will not hinder the operation in conjunction with your rear shock tower brace. Using our Rear Sway-Bar will greatly decrease anti-roll, by keeping the car flat during hard cornering.
1 - 4 of 4 Posts
