Focus ST-R TECHNICAL DATA
Powertrain
• 2.0L EcoBoost I-4
• 250 hp est.
• 250 lb.-ft. of torque est.
• Ford Racing custom exhaust
• Ford Racing engine calibration
• Ford Racing high capacity radiator
• Ford Racing clutch
• Ford Racing oil to air oil cooler
• Remote oil filter
• 6-speed manual transmission with limited-slip differential
Chassis
• Weight – 2700 lbs.
• Structural performance: over 20,000 lb.-ft/degree (torsional)
• Seam-welded steel unibody with integrated FIA-certified safety cage.
Front Suspension
• AST performance coilover adjustable dampers
• Adjustable camber plates
• Ford Racing upgraded sway bar with adjustable end links
• Upgraded bushings
Rear Suspension
• AST performance adjustable dampers
• Control-blade multilink rear suspension
• Ford Racing upgraded swaybar with adjustable end links
• Upgraded bushings
Steering
• Electric steering with unique Ford Racing calibration
Brakes
• Front: 336mm 2-piece rotors with race pads
• Rear: 271mm production with race pads
• Ford ABS with unique Ford Racing calibration
Wheels & Tires
• 18-inch BBS CF 1-piece cast alloy wheel (Anthracite)
Fuel System
• ATL® 18-gallon fuel cell with custom single-dry-break system
Exterior
• Brake cooling ducts
• Hood pins
• Ford Racing front/rear tow hooks
Interior
• Ford Racing lightweight wiring harnesses
• RECARO Pro Racer HANS® racing seat
• AiM MXL Pista GPS-based data system
• Ford Racing short throw shifter
• Ford Racing fire suppression system
• Ford Racing 6-point safety harness
• Ford Racing driver safety nets
• Ford Racing steering wheel with quick release
Download It: View attachment Focus_STR_Specs.pdf
Powertrain
• 2.0L EcoBoost I-4
• 250 hp est.
• Remote oil filter
Chassis
Front Suspension
• Upgraded bushings
Rear Suspension
• Upgraded bushings
Steering
Brakes
Wheels & Tires
Fuel System
Exterior
• Hood pins
Interior
