Focus ST 2013-14 3" Stainless Steel Off-Road Downpipe | Spool
Focus ST 2013-14 3" Stainless Steel Downpipe W/ Cat | Spool
Today we will be installing our 3" stainless steel off-road downpipe on our 2013 Focus ST. These downpipes are available in a catted or off-road version and will fit all '13-'13 Focus Sts. These direct replacement downpipes are a great way to improve both the sound and performance of your Focus ST. Not only will they add horsepower, but also give your ST a more aggressive sound.
These downpipes are made of 3" 304 stainless steel, have a durable 4" Flex section, are CNC machined v-band flange and include 2-1/2” & 3” gaskets to match stock or aftermarket cat-back systems
The catted version comes with a MagnaFlow 200 cell count high-flow catalytic converter.
Installation is pretty straight forward, although disconnecting your O2 sensors and removing the factory downpipe can be a little tricky. This install an be down in an hour or 2 using a few simple hand tools but we recommend using an impact gun if possible. You will want to make sure your engine is cool before starting the installation.
If you are looking for a high quality downpipe for an inexpensive price, than you will definitely want to check out these downpipes available exclusively at Spool Tuning.
For more Spool Tuning options of Focus ST parts check out:
Focus ST | Spool Tuning
