Hawk Performance HB478Z.605 Focus ST 2013-14 Pad Rear Ceramic
Hawk Performance HB712Z.680 Focus ST 2013-2014 Ceramic Pad Set
Today we are installing Hawk Performance's ceramic brake pad sets on both the front and rear brakes of our 2013 Focus ST. When you're driving, the last thing you want to have to worry about is if you're going to be able to stop safely. This set of Hawk Performance Ceramic Front Brake Pads for all 2013-2014 Focus STs is available now at Spool Tuning.
This high quality ceramic brake pad formula has a linear friction profile that enables your ABS system to work more efficiently and effectively. This Performance Ceramic is ultra-high quality and is designed and engineered to cut down on brake NVH. It affords for a quieter, smooth ride with virtually no brake dust being created and inhibiting performance or dirtying up your wheels. You'll also enjoy your rotors and pads having a longer life to live. These are rotor friendly pads that produce steady friction output levels, creating solid and dependable stopping ability and power that simultaneously creates minimal brake dust to combat.
As we demonstrate, installing these brake pads is fairly simple and can be completed in 1 to 2 hours.
For more Spool Tuning options from Hawk Performance, check out:
Hawk Performance | Spool Tuning
