The wheels on mine are from a 2012 focus also. No sensors though the guy transfered them to his newer wheels before I bought themSounds good, thx. I figure Pennsylvania winters get pretty rough and with all the road crud on your wheels, why bother trying to keep those pretty after market mags clean. Just picked up a set of 16" steel wheels from a 2012 focus that wrecked with the pressure sensors still on. I have not heard of anyone going this way for winter wheel setup, thought I was only one.
Odd, says nothing like that at all in the the ST supplement section about wheels and tires. In the supplement it does say in black and white on page 17 the recommended size on the ST for Tire Chains is P215/55R16. This is the exact size of the standard steel wheel on a focus, and while tight, it does fit as long as external wheel weights are used.I was at the dealer yesterday and was going to buy steelies for winter. Was then told I'm not allowed because it voids warranty from ford. They say the need to be an open rim to vent the breaks? But come oon... It's winter? They really going to get that how? They say ford recommends the black rim with polished face that are on the base focus. The 17s for winter.
USING WINTER TIRES
The original equipment tires on your ST
vehicle are designed for maximum
performance in dry and wet summer
conditions. They are not designed for
winter use on ice or snow and cannot be
used with snow chains. Ford does not
recommend using the original equipment
tires when temperatures drop to
approximately 40°F (5°C) or below
(depending on tire wear and environmental
conditions) or in snow and ice conditions.
You must use winter or all-season tires if
you will be operating your vehicle in these
conditions.
• Even with clear, dry driving conditions
do not operate your vehicle above
posted speed limits or perform high
speed maneuvers with winter tires.
• Do not use tire chains on the original
wheels and tires of your vehicle. The
use of any type of tire chain on these
tires may damage your vehicle.
The following table lists acceptable tire
sizes for winter tires. Tire speed and load
ratings should match those of the originally
equipped tires as closely as possible. If it
is required to fit winter tires with a speed
rating less than the original equipment tires
(to fit snow chains, for example), be aware
of the maximum speed rating for the tire
and never exceed.
Compatible Snow Tire and Wheel Packages
Tire size Required wheel
205/40 R17 Original equipment ST wheel or equivalent
Owner supplied. See your Ford dealer for
suitable wheels from the Fiesta lineup.
195/45 R16*
* Required size to prevent vehicle damage if snow chain use is required
Please call the Ford Performance Info
Center at 1-800-FORD-SVT (367-3788)
for specific winter tire recommendations
Minimum tire size for the Fiesta ST would likely be 195/45 R16 with 4x108mm wheel bolt pattern, while '12+ Focus uses 5x108mm wheel bolt pattern.Interesting. Now do the Focus and the Fiesta have the same size brakes? I assume they have the same bolt pattern.
My daily is a 1991 Daytona Shelby, which has 11" brakes front and back. The stock wheels are 16", but I'm able to run 15" wheels for my snow tires. Being as the Fiesta has similar sized brakes, I was hoping a 15" wheel would also fit that car. According to the spec sheets on Tire Rack, the 15" equivalent to the current 17" tires' OD is 195/55/15, which ironically is the stock size for the wheels on her Honda Fit Sport that the Fiesta is replacing.
This ^^. Although the 2000-2011 Ford Focus, 1995-200x Contour, etc also shared the 4x108 mm bolt pattern.Minimum tire size for the Fiesta ST would likely be 195/45 R16 with 4x108mm wheel bolt pattern, while '12+ Focus uses 5x108mm wheel bolt pattern.
