Thanks Josh. I want to make sure that when I receive my ST the dealer does not try to switch tires on me. If they do I will know they are shit and I can promptly leave.235/40/18 Goodyear Eagle Asymmetric 2's
It is hard to pick up on sarcasm through the internet...but I think this is one of those times when I can safely say you are being sarcastic. To that I then say lolWhy would you even suspect such a thing?!
I was but it was the way you structured your sentence. I couldn't tell if you were being sarcastic and I didn't know if you had the same mistrust with a dealer as I did.I'm not. I thought you were dead serious in your question and concern. Couldn't imagine not trusting the dealer at such a level
Dealers in generalNo, and if I didn't trust the dealer, I sure as hell wouldn't buy a car from them.
Does anyone know how these tires do in cold weather? I understand they are a summer tires, but I can't justify a new set of tires on a new car because the temps here get down into the teens. I don't plan on driving in the snow with the new Focus ST, (have 4X4 for that) but the car is cheaper to drive than the truck.235/40/18 Goodyear Eagle Asymmetric 2's
It wouldn't be any worse than all-weather tires in summer.You do not want to drive summer tires in teen Fahrenheit, even when it is dry.
Krzys
Some of the tire manufacturers even say you shouldn't store summer tires at that temperature. If you look at the C&D comparo on summer tires that includes our goodyears they show cracking that can be caused by low temperature storage (let alone use). It's not even close to what all seasons are like in the summer.It wouldn't be any worse than all-weather tires in summer.
Seriously, though. I have no idea about snow, but there's no reason you won't be able to drive the Goodyears in teens weather in the dry. You just won't have as much grip.
Just like when its 114F outside, you won't have very much grip...for long.
But its not like you'll be on ice. It just takes a lot longer for the tires to get to temp.
It gets harder and more brittle. It certainly can damage the tire in addition to being unsafe as grip is dramatically reduced. Why do you think the tire manufacturer says not to use them in near freezing temperature or store bellow freezing. They designed the tire and know what they are talking about.I'm still trying to find out if cold temps degrade the tire faster or have an overall loss in grip in the cold. Anyone have a case study or good article on this? I can't seem to find what I'm looking for. My guess is that summer tires have harder compounds although won't damage the tire you will reasonably have less grip.
I imagine this was the case but with proper warmup you should be able to maintain integrity or mitigate degradation.It gets harder and more brittle.
Not entirely, they also still want to be profitable.Why do you think the tire manufacturer says not to use them in near freezing temperature or store bellow freezing. They designed the tire and know what they are talking about.
In regard to the winter temps, I'm sure you're correct. I'm ignorant to anything but basic driving in below freezing temps. Although we always have summer tires on our cars, and have certainly driven (even at the track) in freezing temps with no immediate ill effects on summer tires. That doesn't mean I didn't degrade them faster. But that was relative in my case. Once I heated up summer tires in freezing temperatures, they operated just fine, though not optimally. Although the optimal operating temperature for summer tires is *unbelievably* narrow.Some of the tire manufacturers even say you shouldn't store summer tires at that temperature. If you look at the C&D comparo on summer tires that includes our goodyears they show cracking that can be caused by low temperature storage (let alone use). It's not even close to what all seasons are like in the summer.
Summer tires will have softer compounds, in order to heat up more quickly and provide better grip. Because of this, they also heat cycle more quickly.I'm still trying to find out if cold temps degrade the tire faster or have an overall loss in grip in the cold. Anyone have a case study or good article on this? I can't seem to find what I'm looking for. My guess is that summer tires have harder compounds although won't damage the tire you will reasonably have less grip.
