I thought I would post this up.
TSB
13-9-7
  • DRIVEABILITY CONCERNS WITH DIAGNOSTIC TROUBLE CODE (DTC) P0106 OR P0236
Publication Date: September 6, 2013
FORD:
2013-2014 Focus
[h=3]ISSUE:[/h]Some 2013-2014 Focus ST vehicles may exhibit difficult to start, runs rough, crank-no start, lack of power, loss of idle RPM or hesitation concerns with DTC P0106 and/or P0236. These conditions may be caused by a wiring concern in signal return splices.
[h=3]ACTION:[/h]Follow the Service Procedure Steps to correct the condition.
[h=3]SERVICE PROCEDURE[/h]
  1. Using Integrated Diagnostic System (IDS), check for DTCs.
  2. Does the vehicle exhibit a drivability concern with DTC P0106 or P0236?
    1. Yes - proceed to Step 3.
    2. No - this article does not apply. Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) Manual for normal diagnosis.
  3. Replace signal return splice with 0.75 mm (18 AWG) wire using the crimp method. Affected splice numbers are S132 and S133. Refer to Wiring Diagram, Section 5-1.
    1. Remove the engine appearance cover.
    2. Remove the air cleaner tube from the housing.
    3. Disconnect the tube for the engine sound symposer at the intake manifold.
    4. Position and secure the upper radiator hose aside using mechanics wire or equivalent.
    5. To increase access to the wire harness release the support clip from harness to coolant inlet valve hose.
    6. Remove enough harness wrap to locate and replace splices.
    7. Backfill the crimp with solder before sealing repair with heat shrink tube.
    8. After wire repair, reverse the removal procedure.
      Obtain Part Locally
      Description
      5" - 0.75 mm wire (18 AWG)
PART NUMBERPART NAME
3U2Z-14A088-BATerminal Kit
[h=3][/h]
