Butalbital is a barbiturate that acts as an analgesic to treat headaches. It has an intermediate duration of action. The medication is often combined with other substances such as acetaminophen, aspirin, caffeine, and codeine.
The FDA approves the formulations combined with codeine for the treatment of complex headaches.
Butalbital and talbutal have the same chemical formula but a different structure. You can opt to order Butalbital online in combination with other preparations:
  • Butalbital and acetaminophen: bupap, axocet, and forte
  • Butalbital, acetaminophen, and caffeine: Fioricet, Esgic, orbivan
  • Butalbital and aspirin: axotal
  • Butalbital, aspirin, and caffeine: Fiorinal, fiortal, and fortabs
  • Butalbital, acetaminophen, caffeine, and codeine: Fioricet#3 with codeine
Butalbital, acetaminophen, and caffeine is a widely used form of medication. The FDA approves this combination for the treatment of complex tension headaches that are caused due to muscle contraction.
Uses
Butalbital, acetaminophen, and caffeine medication combination are useful to relieve symptoms of muscle contraction headaches.
Butalbital belongs to the barbiturates class of medicines that act in the central nervous system to create their effects of pain relief.
Acetaminophen is an antipyretic and non-opioid medication that helps reduce fever and lessen pain. The medicine does not become habit-forming with continued use. However, it may cause severe side effects when taken at higher doses, including fatal liver damage.
Caffeine is a stimulant substance. It stimulates the central nervous system and increases the effects of acetaminophen.
The combination of Butalbital, acetaminophen, and caffeine may also be used to treat and manage migraines.
What does Butalbital look like?
Butalbital is available in combination with acetaminophen and caffeine. You can buy Fioricet online with the following specifications:
  • Color: white or light blue
  • Strength: 325 mg/ 50 mg/ 40 mg acetaminophen/ Butalbital/ caffeine
  • Imprint: WATSON 3369
  • Shape: round
  • Size: 11.00 mm
Overdose
Taking an overdose of any medication can be life-threatening. You should buy Butalbital online to use it precisely as directed by your doctor. If you overdose Butalbital or its combination products or take it with some other CNS depressant such as alcohol or alcoholic beverages, it may lead to unconsciousness, depressed breathing, or even death.
Signs of Butalbital overdose include confusion, severe drowsiness, shortness of breath, severe weakness, slurred speech, troubled or slow breathing, staggering, and unusually slow heartbeat.
Overdosing Butalbital alone can be dangerous, but overdosing on acetaminophen can be fatal. Signs of acetaminophen toxicity may not happen until 2-4 days after you overdose on it. You must still visit the emergency room to start the treatment to prevent severe liver damage or death within 24 hours.
Side effects
The frequent Butalbital side effects include:
  • Dizziness
  • Drowsiness
  • Impaired breathing
  • Intoxicated feeling
  • Sedation
  • Lightheadedness
  • Euphoria
  • Nausea or vomiting
How long does Butalbital stay in your urine?
Barbiturates like Butalbital are detectable in oral fluids and plasma within 15 to 60 minutes of the medication's oral administration.
They remain detectable in the first urine pooled collection at 2 hours.
Butalbital, in particular, stays in the urine for 48-52 hours.
