A few threads had questions about wheel specs. Here they are...
18 x 8.0
55 mm offset
backspacing = 169.5 mm / 6.673 in
63 mm center bore
weight = 25 lbs (hey, it's gotta pass durability!)
tire pressure = 36psi
same size as optional 18" titanium wheels
16" wheels will fit over the front brakes.
Spare is just a base SE 16" steel wheel with the Continental all season tire mounted
I wouldn't recommend lower offset wheels as the KPO and scrub start to get big and not good with low profile tires and a bunch of torque and braking capacity.
Definitely get snow tires if you live where it snows. I'm not a fan of all seasons esp for performance cars. They're a compromise in the winter and a compromise in the summer. Owner's call though...
Ride v. good for a 40 series tire.
18 x 8.0
55 mm offset
63 mm center bore
